Custom Printing Service
250
08-15-2025 10:05 AM
becyr
Hi all I need help with publishing a print service tool from ArcMap to ArcGIS Server 10.9.1 Federated. So that I can utilize the print service in ArcGIS Online Experience builder. Just an overview- I can't downgrade ArcGIS Pro to 2.9 and I can't upgrade ArcGIS Server to 11.3 due to compatibility issues with existing workflows. I'm currently limited to the following setup:
ArcGIS Enterprise (federated) 10.9.1
ArcMap 10.7.1
ArcGIS Pro 3.3
I published a printing service from ArcMap, but when trying to use it, I received the error:
"Web map as JSON is required."
What could be causing this issue?
When testing the tool from the Rest Service I get the following error.
Job Status: esriJobFailed
Job Messages:
  • esriJobMessageTypeInformative: Submitted.
  • esriJobMessageTypeInformative: Executing...
  • esriJobMessageTypeError: Failed.
  • esriJobMessageTypeInformative: java.lang.Exception: Could not service request.
sxw_eaglegis
Hi there,
A few questions for you:
  • Are you publishing using the Export Web Map from the Server toolbox? or a custom python script?
  • What happens when you configure the service with ArcGIS Online Experience builder and test with the print widget?
  • Is the ArcGIS Enterprise 10.9.1 site external facing? and print service shared with everyone?
becyr
Hi @sxw_eaglegis
  • Are you publishing using the Export Web Map from the Server toolbox? or a custom python script? I am publishing from the history as provided on the Esri guidelines
  • What happens when you configure the service with ArcGIS Online Experience builder and test with the print widget? I first had an issue of adding the print service but after multiple trials I was able to add the tool. When testing it on experience builder it runs but doesn't generate an output.
  • Is the ArcGIS Enterprise 10.9.1 site external facing? Yes and print service shared with everyone? Yes
sxw_eaglegis
When testing it on experience builder, if you open the developer tools in your browser and submit a print, can you see what the messages returned are? You will see an execute operation in the network tab e.g.
Are you able to share the print service URL with me?
