curves
2627
11-09-2023 06:48 AM
ndunn54
Is there a curve calculator in pro like there is in arcmap?
Tags (3)
TimHodson
Hello @ndunn54 the Circular Arc tool can double as a curve calculator.
Here's a previous post with the same question that has more information about that: https://community.esri.com/t5/arcgis-pro-questions/curve-calculator-for-arcgis-pro/m-p/393360#M17395
Does this help for your situation?
-Tim
JeffWard
Honored Contributor
They have an edit tool that works like one. I use it by creating a line or polygon feature, click once on the map to start a sketch, then right click and choose "Circular Arc", I then fill it in with the parameters I have, let's say I know the arc length but want to know the delta angle. I enter the arc length, then change the parameter type to delta angle.
Jeff Ward
Summit County, Utah
TimHodson
-Tim
ndunn54
@TimHodson That is more of what I was looking for, thanks!
