Credits and analysis privileges Error for Network Analysis
1183
05-10-2019 06:20 AM
CharlieHarper3
I'm receiving an error trying to run a simple route analysis. When I try to solve I get:
030193: Network analysis solve authorization failed.Credits and analysis privileges are required to perform network analysis.
I'm logged in as an admin, have credits, and solving other types of network analysis layers works fine. Any thoughts?
Tags (1)
CharlieHarper3
Upon further inspection the error occurs only after more than 2402 stops are loaded in the route layer. Thoughts?
George_Thompson
Esri Notable Contributor
I would recommend contacting Esri Technical support with this issue. They can investigate and report back if there is a limitation or other potential issue.
--- George T.
