Creating Street Intersections
2705
04-18-2022 01:43 PM
Labels (2)
analyzethis25
I am needing help populating intersections for a road centerline layer. Within my RCL table, I need to add cross streets/intersecting roads for each road segment. I have attached a couple images for reference. For example, the highlighted segment of W Ross St intersects with two roads, S Cherokee Ave and S College Ave. Within the attribute table, I need to show those intersections for that segment of W Ross St. I also attached an image of part of the RCL Attribute table showing the intersection columns that I need to populate for any given road segment.
Any help you all can give, would be greatly appreciated.
Thanks!
SteveCole
Honored Contributor
Look at the answer here by Dean. It sounds like this will accomplish what you want. I haven't run through those directions so I can't say that it does or doesn't do what it claims.
Steve
analyzethis25
Thank you for your reply! I have seen that article, but that process requires tools that I do not currently have licensing for. I was hoping there might be a simpler solution.
