Creating Network Dataset with ArcGIS Pro
7084
09-10-2015 10:01 AM
Wai_LamWong
I'm new to ArcGIS and I'm trying to follow the Network Analyst Tutorial using ArcGIS Pro.
I have the Network Analyst license enabled (I checked by going to Project -> Licensing -> Esri Extensions), but I'm having trouble with step 8 of Excercise 1. When I expand "New", I only see "Feature Class" and "Relationship Class".
The tutorial refers to ArcMap; is the New Network Dataset wizard located somewhere else in Pro?
Exercise 1: Creating a network dataset—Help | ArcGIS for Desktop
8. Right-click the Transportation feature dataset and click New > Network Dataset.
Choosing New Network Dataset
Thanks for your time!
MelindaMorang
Unfortunately, it is not possible to create a new network dataset in Pro 1.1.  This functionality will be available in a future release.
For the mean time, you need to create network datasets in ArcMap or ArcCatalog, but once you have created them, you can use them in Pro.
MelindaMorang
Wai_LamWong
Thanks for the clarification, Melinda.
1. ArcGIS for Desktop has ArcGIS Pro and ArcMap, but it doesn't include the ArcCatalog program. Does this mean that I can perform all tasks without ArcCatalog? Or is there some functionality that ArcCatalog provides which Pro and ArcMap cannot?
2. Is there any benefit to doing this tutorial in ArcGIS Pro or should I just do it in ArcMap?
BruceHarold
Esri Frequent Contributor
Desktop includes ArcCatalog, look in the ArcGIS program group.
