Creating a new Layout with python
8671
6
03-30-2021 03:16 PM
HaileyG
I am trying to write a python script that will allow me to create multiple templates based on page size/ setup. I am trying to figure out how to insert a new blank layout tab using python script. Does anyone know the syntax for this?
Any other help with python scripts for layout formatting would also be greatly appreciated.
Thanks!
TomBole
HaileyG
Thank you!
pkaniouras
Hi there!
Did you figure out how to create a new layout? All the scripts I read just open an existing one.
Hailey_G
No I was never able to figure it out. I ended up creating a master aptx, without a script, with all of the layouts I would need. Then when I open it, I choose the layouts I want and delete the others.
HaDoMinh
Hi HaileyG,
I hope that will help you
#Create the new layout
layout_name = 'layout_test'
layout = project.listLayouts()
print (layout)
#Check if the layout exits already, if not, create it
if not layout:
print ('No Layout')
layout = project.createLayout(210,297, 'MILLIMETER', layout_name)
else:
print ('we have one layout')
layout = layout[0]
print (layout.name)
How to create new Layout using arcpy was list under is acpy.mp class and also mentioned in Layout class. as TomBole mentioned.
HaDoMinh
project  = arcpy.mp.ArcGISProject(project_path)
if you wonder what is the project
