Create Tile Package stuck at 100% for hours
14139
18
06-10-2020 12:26 PM
MelissaDaniels1
I'm trying to create a tile package in ArcGIS Pro to use on a Collector map. I'm using clipped NAIP imagery. It keeps getting stuck at 100% for hours and not completing. I've tried leaving it overnight. It has all the required things: pyramids, a map description, etc. I've tried restarting Pro and restarting my computer. I can't figure out what could be preventing it from completing and would very much appreciate any suggestions. My Pro version is current.
Thanks!
MR14
I've found a solution working in my case.
Similar as described here https://community.esri.com/t5/arcgis-pro-questions/arcgis-pro-geoprocessing-tool-stuck-at-100/m-p/57... maybe the _  in some names was a problem. Because now instead of  40+ hours to infinity, it took  3 hours  25 minutes for a maximum detail level of 16. Minimum level was 0.
Everything else I did as described here: https://www.youtube.com/watch?v=D4jXNngH7Lg
JoabelBarbieri
Same here. Anyone with a workaround ?
ElizabethZizzamia1
Hello, I'm running into this problem too. I actually need a tile package and can't just make cache. I've run sample data sets that are small, super simple with only a few high level tile levels and it just hangs at 100 and I end up killing it. Has ESRI created a bug for this?
JohnGallop
Come on ESRI, you have plenty of people paying and arm and a leg for your services...have you sorted this issue? I have come across the same issue.
DWR_BuckEhler
I am also having this same issue with a non-naip based service. I have been able to get it to work at zoom level 12 but nothing above. ZL 12 is not useful for any on-the-ground mapping though.
Any tips or help from a helpful ESRI person would be great!
Thanks to the community for your answers and suggestions.
Buck
JohnGallop
I was able to achieve what I wanted to (but had to use credits) by creating a Web Map instead of a Tile package FYI.
MicZatorsky_AEC
I have this issue with ArcGIS Pro 3.1.2  I have tried multiple attempts at Create Map Tile Cache and all get stuck at 99%.   The right amount of cache is created in the right folder during the time estimated, but it never sticks the landing.  It just does not finish.
I tried removing all spaces from names and paths, moved everything to a local SSD, checked geometry errors, put on a magnetic bracelet and lit an aromatherapy candle.  Still no joy.   I wrote an arcpy script and didn't even open Pro, and it still failed to complete even one level of map tile cache.
I disconnected my company VPN, and on the next attempt, the Python script worked!  This is now repeatable.  arcpy.management.CreateMapTilePackage() succeeds when the script is started with no access to the company network.  If the script starts with network access it never completes.
I have since found the same happens in Pro using the GUI.  It works when no company network is available.
I have no idea if it is related to accessing the licence server or some firewall rule on my company's side. But I you are stuck too, try checking out a licence pulling the blue cable and disconnecting from wifi.  Strange but true.
Laura
by MVP Regular Contributor
I am also having this same issue in Pro 3.2. The tool has been running all afternoon at 100%
KaraG
Same issue 😞 Trying to run Create Map Tile Package. It zooms right up to 100% and then never completes.
