Create Sightlines only creating one set of lines
803
12-06-2022 10:50 AM
WhitneyRScott
Hi! I've been playing with the create sightlines tool and have changed a couple settings and keep getting the same result. I have 3 observer points and one line I'm trying to construct between. The output keeps being only 3 lines (one from each observer) to the beginning of the line. I've made the sampling distance a broad range of values and keep getting the same result. Help please!
DanPatterson
MVP Esteemed Contributor
Construct Sight Lines (3D Analyst)—ArcGIS Pro | Documentation
What parameters did you use?
do both observer and targets have z values defined?
and specifics on coordinates etc would be useful
... sort of retired...
