Customized addin, DockPanel interface not updating even deleting and reinstalling the addin
1006
12-06-2022 04:18 PM
MarlonJoseBaldo
hi.
i created an esriaddin with dockpanel (for desktop using c# wpf) and installed it to another computer. the problem occur when i install the updated version of the addin ( it installed successfully ) but it does not update the interface, it retain the previous interface. even if  i remove the addin and reinstallled it, it displays the same old interface.
i would like to know solution to this problem.
thank you in advance for your help.
Marlon Baldo
AnthonyRyanEQL
How did you install the add-in? ArcGIS Pro has a sequence of where to look for addins. I have seen this before where the updated one was in a folder defined in the addins location config and the old one was still in the Documents folder which happens to be the last place to load from and therefore my old addin was being loaded again.
I can't remember the sequence but it's documented in the SDK github pages somewhere
MarlonJoseBaldo
I installed it by double clicking the .esriAddinX file.
thanks for response.
