Create mobile geodatabase (.geodatabase) with python and ArcGIS Pro document, maintaining layers symbology
16865
7
10-30-2025 08:36 AM
PaulCone2
Hi ArcGIS Pro team, cross-posting this from Python Questions.  ApplySymbologyFromLayer with mobile geodatabase is not working for me.  Have to fall back to ArcMap to do this properly.
Re: Create mobile geodatabase (.geodatabase) with ... - Esri Community
sjones_esriau
Unless you need a mobile geodatabase for compatibility with another product, mobile map packages (.mmpk) are the way to go these days.
Created via Pro or Python, the single file retains data, symbology, book marks etc and can be read directly by any ArcGIS client.
PaulCone2
@sjones_esriau I'm familiar with pretty much all the various formats that end clients that use for GIS.  Our 911 dispatch system vendor is still using .geodatabase files for pop-ups in Esri ArcGIS Runtime 200.x.  So yes, I need a mobile geodatabase for compatibility with another product.  If you are saying that ApplySymbologyFromLayer is not working properly here, then I'll be opening a support ticket with ESRI, unless you can tell me here what else I should try.
HaydenWelch
MVP Regular Contributor
Do mobile databases store layer symbology? I thought they only stored feature data and symbology exists in the map that's sourcing that dataset. If you need to use a .geodatabase, you can export a .mapx alongside it that has all layers pointed to that database as a relative path.
PaulCone2
A layer in a .geodatabase exported from ArcMap shows symbology in ArcGIS Runtime without a .mapx file.
ChristineSalvadore
We likely have the same problem - also need this for a CAD vendor for our 911 system. Have you made any progress on this? I recently learned that if you export your layers into a .mmpk, the .mmpk file can be extracted with 7zip, and a folder will appeared called "commondata" which will have the mobile geodatabases in it with the set symbology intact. They seem to be split into unique mobile geodatabases by database source within the map I packaged. I'm currently trying to figure out a better way to create this or how to do this process programmatically since it's extremely clunky.
PaulCone2
No, have not fixed, but will give your workaround a try, then follow up with a bug report!
(Is it Versaterm?)
ChristineSalvadore
thats the one!
