Create Least Cost Paths using the same starting and ending points
1879
5
11-20-2022 03:32 PM
YandaNhlapo
Hi there
I am trying to create least cost paths using the same starting and ending points, however, I am getting this error: Point is outside of Input Cost Surface. The cost surface is a slope layer that I created from a DEM.
I first checked if the point were within the cost surface and they are, then I reprojected both the cost surface and the points to be in the same coordinate system. This did not work.
I am having the same issue when I try to use the cost path function.
Is someone able to help?
DanPatterson
MVP Esteemed Contributor
You have to pick a destination first.  I don't see it in the maps table of contents.  That is, you have to go somewhere before you can return
... sort of retired...
YandaNhlapo
Hi Dan
Thank you for your reply.
I am not entirely sure I understand what  you are saying. So the 'settlement_tlokwa' point layer is the layer that I want to use as the source and destination. Are you saying that I must first choose the ending point then the starting point?
DanPatterson
basically, you need at least 2 different points.  An origin and a destination.  If they are the same point, you went nowhere, you stayed put, no path to follow.  So pick a destination point which is different than the origin.  Go there, then if you want to see the return path, reverse the order of the inputs and come back
YandaNhlapo
Oh okay, I understand now. Thank you so much for your help!
DanPatterson
no problem.  good luck
