Create Label Class Question
795
08-29-2024 08:56 AM
DEAF_PROBERT_68
Honored Contributor
When you work on labels for a polygon that has a lot of labels. There are some areas that have clutter that makes a hard to read the labels because  of the overlaps or inable to read the map.
Example :
Is there a way for me to put "Lock" for each label class rather than to have Lock for the whole label class ?
Thanks
Laura
by MVP Regular Contributor
You can convert your labels to annotation which would give you full control over the placement of them. You can also set up priority ranking and label buffers.
