Create discrete line segments from points
516
04-16-2026 03:38 PM
Labels (2)
CherylMcGinnis
I have a point feature class that includes an azimuth field (short integer). What I want to do is to draw a single line segment of predefined length from each point along that azimuth. (I need to show the dimensions and orientations of some cantilever signs we're installing.) Any ideas? Either a new feature class or a symbology-based solution would work (provided the latter retains the correct length regardless of map scale).
DanPatterson
DanPatterson
This comes to mind first
Bearing Distance To Line (Data Management)—ArcGIS Pro | Documentation
... sort of retired...
CherylMcGinnis
That did the trick!
