Create animations using notebook
1576
10-12-2023 11:20 AM
brock82
Hello community members. I am curious if there is a way to produce animations using the Python Notebook. I have time series data from models run with many sets of parameters (100+). It would be nice if I could automate this process using a loop statement in the Notebook. Has anyone out there done something like this before? Thanks.
David_McRitchie
Hey Brock,
I'm not sure if this is possible but since your animation is displaying time-enabled data then I would recommend checking out the following sample for adding a map with a time slider to your notebook.
Otherwise, I think this is a good request to add to the Ideas page for ArcGIS API for Python.
Many thanks,
David
Esri UK -Technical Support Analyst
brock82
Hi David,
Thank you for the suggestion. At first glance, this might be helpful. I will have to read through the documentation more thoroughly to see if this provides me with what I need.
Best,
Brock
