Create Address Locator with One Range
539
08-08-2024 12:06 PM
AmoryKisch
In ArcMap (ArcGIS Desktop) when creating an Address Locator, there was an option for the locator style US Address--One Range. This allowed you to create a locator from a dataset that only has one set of address numbers per line segment, instead of one for each side (Dual Ranges). This option is not available in ArcGIS Pro 3.3.1? When creating a locator using the Street Address role, it requires you to provide ranges for both sides of the street. This leads to erroneous results when there is only one address range in the reference table. Specifically, when geocoding, each segment gets only odd-numbered or even-numbered addresses. As there is also no way to specify mixed parity for all segments? How to geocode in ArcGIS Pro with only one address range?
Tags (1)
