I am editing an existing feature layer and existing measurements are accurate if I select geodesic in the measurement tool.
I am using the "copy parallel" tool and want to offset by 25m, however once it is created it ends up being around 20m when I measure it using the measurement tool and selecting geodesic.
Is there a geodesic setting I should be choosing somewhere??
The discrepancy occurs because the Copy Parallel tool in ArcGIS Pro works in a projected coordinate system (planar) rather than using geodesic calculations. As a result, when dealing with large-scale data or working in coordinate systems prone to distortion (such as UTM), the actual geodesic distance may differ from the intended offset.
Instead of the Copy Parallel tool, consider using the Buffer tool and setting the Method to Geodesic. This approach accounts for the Earth's curvature, ensuring that the offset distance remains accurate in geodesic terms.
If your dataset includes COGO-enabled features, you can use geodetic construction tools to generate an exact geodesic offset. These tools are designed to maintain geodetic accuracy.
If your data is currently in a projected coordinate system (PCS), try reprojecting it to a geodetic coordinate system, such as WGS 1984 (EPSG: 4326). Then, run the Copy Parallel tool and measure again to check for accuracy.
The reason your 25m offset appears as ~20m when measured geodesically is due to the distortion effects of projected coordinate systems. Since the Copy Parallel tool does not use geodesic calculations, offsets in projected space may shrink or expand based on latitude and projection properties.
For precise geodesic offsets, it’s best to use the Geodesic Buffer tool or geodetic construction methods instead.
@EditorCarbonNet The Copy Parallel tool will create parallel lines using geodetic distances as long as the map uses a geographic coordinate system such as WGS 1984:
