Corrupt export PDF file in ArcGIS Pro
1178
12-20-2022 05:40 PM
AulianaFikri
Hello. I want to export a land use map (vector) with a scale of 1:100000 and set a reference scale of 1:5000. The file type is pdf and after processing for up to 4 hours, the output file cannot be opened (corrupt). Can anyone help? Disk C has about 40GB left under normal conditions, and 7GB remaining during the export process. Does it have any effect? I am using ArcGIS Pro 3.0.3.
JeremyWright
Lots of possibilities here, so it's best if you contact Esri Support directly and give them your repro case.
As a start for troubleshooting, try lowering the output resolution.
You can also attempt to export as image - either of these strategies should help if the problem is the sheer volume of vector data.
