Copy workspace location in ArcGIS Pro
2549
07-30-2019 01:42 PM
JoeBorgione
Is there a way to copy the path from catalog pane in Pro (2.4 in my case) as you can in ArcCatalog?  It's real handy when writing python :
I can just highlight the path to the table above and paste it directly in my python window:
tableVariable = r'C:\temp\Scratch.gdb\testTable'
That should just about do it....
Robert_LeClair
Esri Esteemed Contributor
Joe - yes there is.  In the Catalog View (not Catalog Pane), navigate to your data source and click the "path" box to the left of the Search Project UI top center of the Catalog View.  Click in the box - the path is highlighted.  From there, do a right click->Copy.  Voila - the path is copy and ready to paste in your Python script!
Robert_LeClair
JoeBorgione
Ah ha!  Thanks Robert!
KoryKramer
You can also use the Copy Path option from the Clipboard group - from either Catalog View or Catalog Pane:
JoeBorgione
Very nice Kory!  Thanks!
