Copy-pasting table into Excel with correct columns
3520
09-02-2021 12:38 PM
AlfredBaldenweck
MVP Frequent Contributor
I have a quality of life question.
If I select rows in a table and press "Copy", then paste them into Excel, sometimes they will paste correctly as separate columns, but frequently they'll all paste into one column.
So for example, my nice table that should look like this
NameParcelAcreageLast updated
Smith, J.1012345.039/01/2021
Doe, J.9823522.108/31/2021
Stone, M.78723240.007/26/2021
is pasted as
Name Parcel Acreage Last updated
Doe, J. 9823522.108/31/2021
Stone, M. 78723240.007/26/2021
I haven't figured out if there's a pattern to it happening or not, but I'd like it to stop. It will happen on a dataset one day, then later in the day it'll work perfectly on the same set.
Is there an easy way to get it to not concatenate into a single column like this?
Thanks!
DanPatterson
MVP Esteemed Contributor
Your first nice table looks like every column is text given the left justification... or is that an artifact of the forum copy/paste
... sort of retired...
AlfredBaldenweck
That's just because I made up this data to write the post. It's been happening with a mix of column types; Text and Numbers will both get squished like this.
I will also say that I've had this issue in Pro and in ArcMap in the past.
DanPatterson
Ahh... ok.  I usually use Table To Excel (Conversion)—ArcGIS Pro | Documentation
after making a selection in Pro or export to csv if using other applications.
I have noticed flakey copy/paste in other applications also but usually when a cell is blank/ <null>
