copy paste data without attachment
1748
11-12-2024 11:11 PM
yockee
I have feature class with huge blob attachment on FGDB. I want to copy just the feature class without attachment.
How can I achieve that ? Special Paste can not exclude the attachment table
thanks
DanPatterson
MVP Esteemed Contributor
I can't test, but the Copy Features tool might work if you check the Maintain Attachments off in the Environments tab
Copy Features (Data Management)—ArcGIS Pro | Documentation
Maintain Attachments (Environment setting)—ArcGIS Pro | Documentation
... sort of retired...
DanPatterson
TonyContreras_Frisco_TX
As Dan mentioned, the Copy Features tool uses the Maintain Attachments setting. The Export Features tool also honors the environment setting. The Feature Class to Geodatabase tool does not list Maintain Attachments, so it might only copy the feature class. Hopefully one of these will work the way you want it to.
