copy a feature class with a related table from a rest service
1509
03-13-2024 01:10 PM
L77
How can I make copy of a rest service point layer that has a related table and have it keep the original global id's and relative id's.
My goal is to create a field app, update the data in the copy then append in the changes to the rest service for both the point layer and the related table using the global and relative id fields for the join.
clt_cabq
I exported a hosted feature layer with a related table to a file geodatabase and inspected it in ArcGIS Pro and it looks like the Global IDs and the ParentGlobalIDs remained the same. Makes sure you test this out before you implement it for real. I'm making an assumption you are using hosted services in AGOL but i don't know why this wouldn't work if you are working with AGS services, just test it out.
When you are on the item detail page in AGOL, you should see a set of options like below - pick export data then export to fgdb and specify where you want the output. Then download that and extract the .zip file this creates to where you want. When you bring it into Pro it will have the same naming as your hosted data, so I would recommend renaming the temp export data so you can distinguish them easily in the join/relate tool or any other geoprocessing tools you might use.
