Coordinates for points in Parcel Fabric
1423
04-06-2023 02:48 PM
FabioLuiz2
I am having an issue with the point layer in my Parcel Fabric. The attribute table is not displaying coordinates for the points. I have checked that the point layer is correctly defined as a Parcel Fabric point layer, the coordinate system of the Parcel Fabric is correctly defined, and the units of measure for the points and Parcel Fabric are the same. However, the coordinates are still not displaying in the attribute table. Can someone please help me troubleshoot this issue?
Estou com um problema na camada de pontos do meu Parcel Fabric. A tabela de atributos não está exibindo as coordenadas dos pontos. Já verifiquei que a camada de pontos está corretamente definida como uma camada de pontos do Parcel Fabric, que o sistema de coordenadas do Parcel Fabric está definido corretamente e que as unidades de medida para os pontos e o Parcel Fabric estão iguais. No entanto, as coordenadas ainda não estão sendo exibidas na tabela de atributos. Alguém pode me ajudar a resolver esse problema?
Tags (1)
jcarlson
The coordinate attributes don't populate automatically, but are for points where the actual coordinates are explicitly given. Most of our points don't have a location, except in relation to another point by bearing and distance. Some points do have coordinates, though, if a surveyor provides the location of a known reference marker, etc., and these points we enter the attributes manually.
- Josh Carlson
Kendall County GIS
jcarlson
- Josh Carlson
Kendall County GIS
