Coordinate table to polygon -tool gives IndexError: List Index Out Of Range
1326
12-05-2022 03:12 AM
satu
Hello!
I have a csv-table with corner coordinates of 10 square-shaped areas. I would like to bring those squares at once to my ArcGis Pro Map project, however running the tool "Coordinate table to polygon" gives me IndexError if I try to bring more than one polygon coordinates at a time.
IndexError: list index out of range
Failed to execute (PointsToLine).
I assume that I'm using the "Line grouping field" feature wrong, but I can't find any examples of how should I do it instead. In my table I have columns for X coordinates, Y coordinates and for unique polygon identifier that tells which corner coordinates belong to each polygon. This should allow me to bring multiple polygons at once. Random coordinates used in example image:
Any ideas what is causing the error and have I understood the tool logic wrong?
RainbowUnicorn
FWIW, I'm having the same issue.  I can get it to run on single areas, nothing on multiple areas...index out of range error.  Ugh.  I wish someone had some advice.
tikola
by Esri Contributor
Got same error with same tools when using shapefiles and joined data. After moving to file geodatabase no problems. So could be that there are some format related issues in these functions that you can avoid by using data from normal file geodatabase.
