Converting polylines to polygons in Arc Basic
851
06-27-2023 02:01 AM
feng192
Is there any advice on how I can convert ~75,000 polylines to polygons in Arc Basic (i.e., without Construct Polygon or Feature to Polygon functions)? I stumbled across ET GeoWizards, but don't know if there's a more seamless solution out there.
GISAdminSHN
Do you have access to AutoCAD?
in CAD, import shapefile - select all polylines - use Object Properties panel, toggle Closed property to Yes - back in ArcGIS add data, browse to CAD .dwg, click in and just add the Polygon features - Export polygon features to shapefile
