Converting Labels to Annotation
1859
03-18-2022 02:48 AM
Lloyd_Moyo
Greetings, i had been trying to convert my labels to annotation I am trying to mask my layers, however Im encountering an error in almost all of my projects except one. Please see the attached error I'm an encountering and assistDatABSE.PNG
tigerwoulds
I see you have a space in your output geodatabase path. In general, it's a big no-no to have spaces or special characters in any paths you'll be using in ArcGIS. Try running it again but replace the space with an underscore or similar.
Robert_LeClair
Esri Esteemed Contributor
Is your data versioned by chance?  If so, there is BUG-000120623 - Failed to run the Convert Labels to Annotation tool on versioned data in ArcGIS Pro when a feature-linked annotation is selected.  One solution is to unregister as versioned, run the tool to create the annotation, re-register as versioned.
Lloyd_Moyo
Im not sure. Tried to create a new geodatabse but I'm still encountering the same bug.
