Convert String field to Date Field
13435
13
01-12-2021 02:00 PM
DonovanC
Does anyone have any suggestions on how I can convert this field into a date/time.  I converted it from kml to shp file and all the information was in one field. I tried using the Convert Time Field tool but it failed.
@XanderBakker
@HusseinNasser2
DonovanC
Hi @XanderBakker
I added in the two additional lines of the expressions but it does not pull the timestamp.
XanderBakker
Esri Esteemed Contributor
Hi @DonovanC ,
As far as I understand, the way a date time is shown in ArcGIS Pro depends on the settings of your system: https://pro.arcgis.com/en/pro-app/latest/help/data/tables/date-fields.htm
You can validate this using the pop-up and define an expression to return the date and time using the format that you want. An example:
return Text($feature["Name of your date field"], "Y-MM-DD HH:mm:ss");
XanderBakker
Hi @DonovanC ,
Earlier on you also mentioned using Python for the field calculation. This should return the same result.
def ParseDateTime(tst):
    import datetime
    dt_format1 = "%d-%m-%Y %H:%M:%S"
    dt_format2 = "%m/%d/%y %I:%M:%S %p"
    if "-" in tst:
        txt = tst[1:20]
        dt = datetime.datetime.strptime(txt, dt_format1)
        return dt
    else:
        txt = tst[1:21]
        dt = datetime.datetime.strptime(txt, dt_format2)
    return dt
ParseDateTime(!kml_des!)
DonovanC
Thanks for all your help!!
