Convert SHP to 3d and back
2298
7
11-26-2024 07:05 AM
JairoCordero
Hi all.
I work in photo interpretation, and in ArcMap I used to use a tool called “FEATUREA TO 3D” and “CONVERT 3D FEATURES TO 2D FEATURES”, but in ArcGIS Pro 3.1.5 I can't find them, could you tell me where they are or which ones I can replace them with?
Thank you all for your answers
Robert_LeClair
Esri Esteemed Contributor
I'm not seeing those tools in ArcGIS Pro so that leads me to believe that there is a new workflow for 3d to 2d conversion.  Here are a few resources to consider...
How To: Convert 3D Features to 2D in ArcGIS Pro
Convert 3D Features to 2D in ArcGIS Pro - Esri Videos: GIS, Events, ArcGIS Products & Industries
JairoCordero
Hi Robert,
These are the tools, I'm working with GDB, feature class. and DTM
Best regards
Robert_LeClair
Hi @JairoCordero - thank you for the screen grab.  Question - what release of ArcGIS Pro was this captured from?  Please advise.
JairoCordero
Hi Robert, I'm using ArcMap 10 and I want to know if the same tools are available in Arcgis Pro?
Robert_LeClair
With the 3D Analyst extension licensed, I can confirm that the "Feature to 3D by Attribute" is in the 3D Analyst toolbox and the Conversion toolset.  The other one, 3D Features to 2D Features" I'm not seeing in ArcMap nor ArcGIS Pro which leads me to believe it could be a custom tool perhaps?
BillFox
MVP Notable Contributor
@JairoCordero is this your previous workflow?
HOW TO
Convert a 2D shapefile to a 3D shapefile in ArcMap
https://support.esri.com/en-us/knowledge-base/convert-a-2d-shapefile-to-a-3d-shapefile-1462480606226...
JairoCordero
Hi BillFox, the screenshot is from ArcMap 10, and I want to know if those same tools are available in Arcgis Pro?
