Convert a SQL table to M2M relationship class table
1791
05-04-2022 05:49 AM
Boyang_Wang
Hello,
I have a many-to-many relationship in an Access database, and I want to export it to my ArcGIS Enterprise SQL Geodatabase. I managed to import the Access database to SQL using SQL Server Management Studio, so now I need to convert the relationship table into a relationship class that can be recognized in ArcGIS Pro. Is there a tool to do this?
Thanks!
RhettZufelt
MVP Notable Contributor
Relationship Class just sets up the relationship between two tables.
Once both your tables are in the geodatabase, use Pro's Create Relationship Class GP tool.
R_
Boyang_Wang
I think what you are referring to are one-to-one and one-to-many relationships. For many-to-many relationship, relationship class need a intermittent table. It seems that Create Relationship Class GP tool can only create new intermittent table but cannot use existing intermittent table. I guess I can create a blank intermittent table using that tool, and append the records from my existing intermittent table in SQL to the newly created table.
RhettZufelt
Not sure about that.  I don't use M:M relationship classes, but  I don't see "intermittent" table anywhere in the GP tool or it's help.  All I see is the two input tables (origin and Destination), and it doesn't seem to matter if I create a 1:1, 1:M, or M:M.
However, if I run the tool with the two input tables, it creates the relationship class.
R_
