Conversion from Raster to Polygon
1515
12-14-2021 04:15 PM
AlexandraVoight1
How to convert raster to polygon if the raster has decimals and I am unable to use the "raster calculator" because it is not licensed? Thank you!! I need to be able to click on different parts of the polygon and see the different raster values, which I will then need to intersect with another feature layer...
Thank you!
AlkaRamnath
Hi
Have you tried the "Raster to Polygon" tool in the Conversion toolbox (Data Management)? It is available in the Basic licence.
Regards,
Alka
AlexandraVoight1
Yes, unfortunately I can't do that because my raster values have decimals and the "Raster to Polygon" only accepts integers...
SteveLynch
What about RasterToPoint and then join these points to a given polygon feature class or ...
