Connecting to a database for feature layer service
754
07-05-2022 02:02 PM
SV24
With my basic level license for ArcGIS Pro - could I connect to Microsoft Access database and create a feature layer service that references the data tables within Microsoft Access? The end goal would be to use the data tables and extract XY points to the map, that I would then publish to ArcGis Online to create a crime map dashboard
RobertBorchert
Honored Contributor
Unfortunately you cannot connect to a Personal Geodatabase with ArcGIS Pro.
If you have ArcCatalog you could import the features and tables into a File Geodatabase and use them.
