Composite Bands Output Issue
1218
05-06-2025 10:11 AM
Ed_
by MVP Regular Contributor
so, i have two rasters, one is a categorical (say 1) that has values from 0-100, and the other is a continuous (say 2) DEM.
The desired band order is 2 and 1
When i run the Composite Bands tool and use the order 1 and 2 for the input rasters i get this output
When i run the Composite Bands tool and use the order 2 and 1 for the input rasters i get this output
Why is the band order 2 and 1 output so different and is not showing any values?
ps ArcGIS Pro 3.4.3 is being used
Question | Analyze | Visualize
DanPatterson
MVP Esteemed Contributor
combine integers with integers or floats with floats, don't mix them.  The type of raster may be determined from the order applied
Check the raster input types, convert to a common type, then see if order affects the outcome
... sort of retired...
Ed_
thank you for the quick response Dan, but it's the same issue even after converting the categorical raster to floating point (similar to the continuous raster) using the Float tool.
DanPatterson
without seeing your legend, I suspect you are just seeing the band that is on top.  You won't "see" through all bands.  My point was about combining rasters, not what they look like.
