Comparing optimized hotspot analysis layers
1461
12-17-2020 08:44 AM
Ashok_kumarSankaranarayanan
Hi all
I am using ArcGIS pro 2.5, I have 9 layers of optimized hotspot analysis of disease with different dates, I like to know how i can compare them with the common attribute like community number,to see the changing hotspots in different community over a period of time.thank you
DanPatterson
MVP Esteemed Contributor
comparing them over time at a location makes sense if you are looking for difference in the patterns at a location.  comparing different locations would require you have some variable which you thinks give rise to the pattern.  do you have such a proposition?
... sort of retired...
by Anonymous User
Not applicable
Dear Friend Mr Dan Pattterson your placements are of high quality, congratulations on predicting them helps a lot and avoids big mistakes. Thank you very much.
Thank you Mr Dan ,I have patients laboratory positive date as variable,for communities ,which changes over time,and to see involvement of community over the specified time period ,Thank you for suggesting valuable points.
