Working with ArcGIS pro and Spot colors
Am trying to export several PDF files for each spot color used in my Layout
Our system is using 7 spot colors which is then separated into several mxds each contains a single color and exported to be sent to printing , this separation process is an old VB code done on 9.3
So my question is ? is this process of separation is available on arcGIS Pro or not ? and if its not available what is the best way of doing a custom code to automate the process using spot colors ?
