Collecting GPS data points using ArcPro
538
06-17-2025 04:45 PM
SeanieMalcolm
I have collected GPS data using ArcPro. I have a point feature class with a data point (roughly) every second. My GPS is set to collect a data point every second. For some reason, I seem to consistently lose 10 data points per minute, non consecutively. Does anyone have any insight as to why this may be happening and how I could avoid it?
RTPL_AU
@SeanieMalcolm Windows doing Windows things? Pro doing Pro things?
Kidding aside - USB or Bluetooth connection? If used wirelessly does it have an option to connect via cable?
Try to connect it to QGIS and capture a stream in it or deploy a quick Field Maps map and repeat the capture using your mobile phone.
You have a few variables at play, two of which are prone to creating headaches; I'd start by making sure the GNSS unit is playing ball and going from there.
