COGO doesn't close parcel curves
685
12-18-2025 12:52 PM
MariyanaKostov1
I've been using COGO to update parcels. It worked great in ArcMap but when I switched to Pro I’ve noticed that the curves get shifted. All this results into lines not closing at the point of beginning.
Has anyone experienced the same and have a solution?
I attached 2 JPGs for better visualization.
Mark_Eygenhuysen
Hi Mariyana, I've been having the same issue. It's driving me up the wall!  My work around is to use only the arc segment's chord data to achieve COGO closure. Then I go back and replace each chord segment with an arc segment using start-end-radius.  Then I use the Traverse-trace option to retrace the entire closed COGO and export it.  Then I edit each arc segment's attribute values to match the correct chord bearings.  Time consuming but effective.
Tags (1)
MariyanaKostov1
I feel your pain! ESRI should do something about this!
LizPeluchette
This is on my last nerve. Esri really needs to fix this. It was working fine until one certain update. I don't know what changed. My workaround is the same.
