Clip tool
974
01-05-2021 08:21 AM
MarcelSt-Germain
Do the use of clipping improve or not the speed to draw a map in map series ? Since the map cover, in my layout, all the place, do it have some speed issue with ArcMap engine to clip or not ?
DanPatterson
What sort of speed improvement are you looking for?
The less you have to load, yes, but I suspect unless your area of interest is exceptionally small relative to the size and complexity of the inputs, you probably won't see much difference.
The simpler the map, the faster it will draw,
... sort of retired...
