Clip to Outline property not applied in service cache
429
05-13-2024 07:31 AM
DeirdreSmyth
I have a map that I have published to a cached map service, in the map properties > Clip Layers section I've clipped 1 of the layers so it does not overlay adjacent layers.  The layer is clipped as it should be in the map but I have published it to a cached map service and in the cached service it is no longer clipped and blocks out adjacent layers.
I am using   ArcPro 3.2, and ArcServer 10.9.
Any help gratefully received,
Thanks and regards,
Dee
**Edit to note I tested publishing to a map service with no cache and it still did not apply the clipping to the layers
