clip line segments
792
04-15-2026 01:20 PM
temprobertcottreau131313
I have 3 line features A, B, C and would like to find where line feature C is the same as line feature A and where line feature C is the same as line feature B.
There are instances where line feature C has portions of both A and B.
Is there a way to do this?
Thanks to all.
DanPatterson
MVP Esteemed Contributor
three separate featureclasses? or 3 features within the same featureclass?
... sort of retired...
3 separate feature classes.
none of the pairwise tools is the solution, at least as I've tried them.
andeb31
Take a look at the Intersect geoprocessing tool. This should get you what you need https://pro.arcgis.com/en/pro-app/latest/tool-reference/analysis/pairwise-intersect.htm
Pairwise Intersect only returns a small number of the sites.
I'm not sure if what I want is possible.  Lines don't seem to want to clip lines based on lines.
JamesPoeschel
Is it possible that your overlapping lines do not overlap exactly? Could you create a small buffer and then run the intersect tool with the buffer? I think that's what I usually do when I need to clip lines with lines.
Alternatively.. I had a similar task once and just asked Claude ai to write me an arcpy python tool and it worked
