Clear highlighted selection from selected records in attribute table in ArcGIS Pro 3.5.1
2093
6
06-13-2025 01:50 PM
Teri_Dane
In previous versions of ArcPro and ArcMap, I was able to clear all highlighted records from my selection by clicking the top left-hand corner of the table. In ArcGIS Pro 3.5.1, when I click the top left-hand corner it clears all records selected, not only the highlighted ones. Has anyone else experienced this? Has this fearture been removed from this version of ArcPro?
BarryNorthey
Not sure if it has changed but in 3.5.1 you will see a section at at the top of the table that says Highlighted: offering various options for dealing with Highlighted records.
BarryNorthey
Ed_
by MVP Regular Contributor
Nope it's still there in 3.5.1, just checked. this is where i clicked
Question | Analyze | Visualize
BarryNorthey
I interpreted the question as how does one clear just the highlighted records in 3.5.1. Clicking at the top of the gutter in 3.5.1 clears all selected records, not just Highlighted records, which seems to be the issue.
Teri_Dane
@BarryNorthey, yes, that is the issue I am asking about. Clicking the gutter in ArcMap would clear only the highlighted records. Did this functionality go away in ArcPro?
Ed_
Sorry, reading your post again, to clear selection within a selection you have to click Clear under Highlighted. Top left corner will clear the entire selection.
DuncanHornby
MVP Notable Contributor
@Teri_Dane I think you have answered your own question. You now have to click the clear highlighted button in ArcPro.
