Classify Pixels using Deep Learning processing mask
1275
01-26-2023 01:49 PM
Jonathan_Pomeroy
Hello, I'm using Arcpro 3.0.3 to classify a large high resolution aerial photo dataset and I need to restrict the deep learning classifier to only classify with in a certain area (purple polygon) and ignore any areas outside. I've set this feature class as the mask in the environments, but haven't had any luck yet. The tool will run just fine, but it will classify the entire scene.
Jonathan_Pomeroy
This tool does not honor the mask. Does anyone have any ideas for a work around?
PavanYadav
@Jonathan_Pomeroy I know it's an old post but there are a different tools that you use. Clip Raster  use https://pro.arcgis.com/en/pro-app/latest/tool-reference/data-management/clip.htm might be easier to use.
A side note: We have an ArcGIS Image Analyst dedicated community and here you might get response sooner.
Cheers!
Pavan Yadav | Product Engineer - Imagery and AI
Esri | 380 New York | Redlands, 92373 | USA
https://www.linkedin.com/in/pavan-yadav-1846606/
Pavan Yadav
Product Engineer at Esri
AI for Imagery
Connect with me on LinkedIn!
Contact Esri Support Services
