Citizen Problem Reporter Solution is not available in ArcGIS Pro
1927
02-15-2021 05:43 AM
KaterynaHolubenko
Hello,
I have a problem with solution deployment in ArcGIS Pro. Earlier I installed "Install Add-In"  when I wa working with Utility Network solution.  But now in the Deploy an ArcGIS Solution task I don't have Citizen Problem Reporter Solution (my main task - it is deployment in ArcGIS Enterprise organization) .
How can I add it to ArcGIS Pro for future work?
And the second question is Can I use a geodatabase instead of so many separate layers on portal?
Thanks a lot.
Robert_LeClair
Esri Esteemed Contributor
Kateryna - I found the Citizen Problem Reporter in the ArcGIS Solutions webpage - and from there did a search on Citizen Problem Reporter to eventually led to this help page - not sure why it does not appear in the ArcGIS Solutions Deployment tool.  The help page describes how to deploy the solution by going here - hope this helps!
GregHorne
I am trying to deploy the Citizen Problem Reporter solution in ArcGIS Online.  When I click on the solution, it spins for a while, counts up and then finished with: Citizen Problem Reporter failed to deploy  Retry.
I have tried the installation with different users including admin users.
Suggestions/Ideas?
