Changing Annotation
979
04-10-2019 06:48 AM
MichelleCouden
I have a geodatabase with traffic counts and their annotation. I want to change the annotation for another project with truck counts. Can I use the same geodatabase and annotation but just change the counts. I can't lose the information though on the first project of traffic counts. Meaning, if I change these counts in the truck project will the traffic project change as well. Hope that makes sense.
Tags (1)
Robert_LeClair
Esri Esteemed Contributor
If I'm understanding the question correctly, you currently have a map with traffic counts (feature class) and amounts (as annotation).  In another map, you want to use the same annotation feature class for the same feature class but update the value in the annotation feature class TextString to reflect truck count AND not impact the first map.  Correct?  If this is true, then no.  Annotation is a feature class just like points/lines/polygons so when edits are made and saved, it's done.  What you may want to consider is an annotation feature class for trucks and another for non-trucks.
