Change default symbology
21840
30
04-06-2021 09:21 AM
IanPryor1
How do you change default symbology for feature classes?
AmyKuhel1
Thank you for responding.  I'm about to head out for the weekend but I will test these Monday morning and report back.
AmyKuhel1
In every scenario, when I add NLD.rehab, it displays with the graduated colors.  In a brand new .aprx with nothing else added.  With the layer added and symbology corrected and a new .lyrx created, when I add a new copy of the layer in, still graduated.
Somehow, the layer in SDE has inherited the symbology.
ColorfulCorvid
This isn't a direct solution, but I was able to get similar functionality by creating a new project template with my preferred symbology already loaded. It won't work for every use case, but it does save me a lot of time.
https://pro.arcgis.com/en/pro-app/latest/help/projects/create-your-own-project-template.htm
MariaCentelles
Has there been any update on the topic?
NicholasBarger
There was an enhancement listed as a solution... but I have not seen any changes to ArcGIS Pro to allow us to change that symbology
Robert_LeClair
Esri Esteemed Contributor
Within the internals, I'm seeing this listed as "In Product Plan."  Not sure when it will be available in ArcGIS Pro.
ErikBreedon
(deleted my question, I saw it answered below)
kronezone
Hello, does anyone know if there any updates on this?
NicholasBarger
Not that I'm aware of.
Robert_LeClair
I looked at the ENH-000137090 status on the internals and no change from in Product Plan.
