Catalog Pane Popup Window Needs to Include Summary
1500
04-15-2020 01:53 PM
CathyWilson2
The Catalog Pane pop-up that appears when you hover over a layer shows the file name, type, modified date and location. Could you add the Summary? That would be most helpful. If it would take up too much screen space, I don't need the Location. I'm in Catalog Pane. I'm looking at it! It would save time Viewing the Metadata.
Catalog pane popup for a recreation layer
Katie_Clark
MVP Regular Contributor
Cathy, it seems this post might be better added to the Ideas section of Geonet, rather than a question? I agree it would be a helpful functionality!
Best,
Katie
If this post helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
CathyWilson2
Yes, that's where I was aiming for, but I see that I missed. Don't know if I can MOVE this, but will create a new post in Ideas and cancel or delete this one!
Thank you!
Cathy
CathyWilson2
Moved to Ideas where it belongs.
I didn't scroll down far enough to see the Ideas option when creating the post!
