Cannot share a Web Map to Portal 10.7.1
1887
6
12-15-2020 05:42 AM
FlorenciaPineiro
I'm trying to share a Web Map from ArcGIS Pro (2.6) to Portal (10.7.1). I'm working with registered feature classes and a table. The Portal active is the Portal of my organization and I've logged with the administrator user.
From Share, I selected Web Map and the I filled the gaps.
As the items have enabled the editor tracking, I tryied to set the time zone. The fact is that the "Configure Parameters" tab didn't appear.
From the Content tab, I selected the Map Image Item and then "Properties".
After that, I could set the time zone.
No messages at all when analyzing, but I no had the Share button anymore.
May you help me?
Thanks in advance.
Tags (3)
2 Solutions
Robert_LeClair
Esri Esteemed Contributor
I see what's happening.  You're "stuck" in the configuration window.  Click the left facing arrow towards the upper left of the window underneath the words "Share as Web Map" to return to the main tool process window.  Then you will see Analyze, Share, and Jobs.
Robert_LeClair
GREAT!  Glad it worked.  If you feel my answer is the correct answer, mark it as "Accept as Solution" to close out this thread.  All the best!
Robert_LeClair
One thing I would try is close ArcGIS Pro and reload your project file.  When you share the Web Map to your Portal, I'd recommend changing the Map View Coordinate System to WGS 1084 Web Mercator (auxiliary sphere) to publish the web map.  Does the issue persist? Please advise.
FlorenciaPineiro
Hi Robert,
Thanks for your answer. I've followed your indications but I couldn't solve the problem.
Robert_LeClair
Interesting.  Right-click on the warning message and it should direct you how to resolve this issue.  Still researching why the Share button is not present.
Robert_LeClair
FlorenciaPineiro
Robert,
I really appreciate your help. It works!! Thank you very much. I'd been leading with this issue for a few days.
Regards,
Florencia
Robert_LeClair
