Cannot Run MSI Installer in SCCM
2519
04-11-2022 09:07 AM
TimSanders
I extracted the ArcGISPro.msi MSI file from the ArcGISPro_29_179927.exe installer and set up the Application installation in Microsoft Endpoint Configuration Manager as I have done in the past without issue.  I set it to install silently and it runs into an 0x643(1603) error.  I changed the installer to run normally so I could see the error, and I got a message stating that I must accept the EULA.
I checked the switches at Install ArcGIS Pro silently—ArcGIS Pro | Documentation and added the ACCEPTEULA=YES as it instructed.  I ran the installer and it still requests I accept the EULA.  I want to set this up to install silently and without user input.  Below is my current SCCM Application script:
msiexec /i "ArcGISPro.msi" ACCEPTEULA=YES ALLUSERS=1 INSTALLDIR="C:\MyArcGISPro\" ADDLOCAL=Pro /qb
This was taken directly from the ESRI documentation.  I did move the ACCEPTEULA=YES up, but that is the only change I made and it didn't work as written in the documentation anyway.  I set the Application to install only to System, not to user.
Thanks.
RichardDaniels
MVP Regular Contributor
same issue with ArcGIS Pro 2.9, did not have with Pro 2.8 and prior.
when I UPGRADED 2.8 to 2.9 the installer works, fails for a clean install (no pro previously loaded)
