I have a score field in the attribute table. I can not edit its value although I can edit the rest of all filed. I couldn't find its reason.
Also, I cannot delete the field although I can delete the rest of all filed
Thank you
Would you be able to share the feature class?
Hi Uri Gilad
Thank you very much.
Is it enough to share just the SHP file? If yes, I send it to you attached.
Thank you
Hi Umit, the shp cannot be opened on it's own. You'll have to attach the complete shapefile (e.g. shp, dbf, sbx, etc.), or a geodatabase with a feature class.
There are no problems when I open the file on my ArcMap. I can edit and delete the Score field:
Some possible solutions:
1. Try to delete/change the field on the rar file you've sent me. If it works then your original file might be corrupted.
2. Did you join fields before you tried to delete/change? If yes this might have to do with a joined field not responding to your editing because it was actually not a part of the feature class.
3. Try to open the feature class in a new project and test.
4. Are you reading it from an SDE? If yes try to export to local and then edit. If it works then it's a lock issue on your SDE.
