Cannot copy and paste from Excel to a related table
1873
03-20-2024 09:26 AM
JefferyRebitzke
Hello. I have seen several tutorials on copying and pasting attribute data from one spatial feature to another spatial feature, but when I attempt to do this using non-spatial attributes from two tables, I receive the following: "There are no appropriate templates."
I am trying to copy some attributes from an Excel document to a related table in ArcGIS Pro. In the Editor Settings, I created the Field Mapping that matches the Target and Source fields. I start my editing session, highlight and copy the source attributes, but when clicking Paste Special, I receive the error every time.
I'm starting to think this copy/paste option might not be available for attributes in non-spatial tables but am not sure why. In my project, I have a survey polygon with a related 1:M table where I need to populate 50-125 tabular records for each spatial feature. The user would then use Field Maps to answer mostly Yes/No questions for each record in the related table. What I don't want to do is manually type in several hundred records one-at-a-time.
Any help would be most appreciated.
RhettZufelt
MVP Notable Contributor
If you add the Excel table to the map, the Append GP tool will do that.
R_
Robert_LeClair
Esri Esteemed Contributor
I'm thinking that because MS Excel files are read-only in ArcGIS Pro that likely there are some other nuances, like copy/paste, that will not work.  What you could do is use the Export Table GP tool and export the Excel table to a geodatabase table.  Then try to do the copy/paste workflow again.
