Can the Refresh Datasource command be automated in Tasks?
1193
02-04-2025 11:42 AM
Labels (2)
Michele_Hosking
I am still trying to find a solution to the problem identified in this idea post:  Refresh Datasource arcpy command
I am running a python script which is in a toolbox tool and running from a task.  It updated the attribute table only in a versioned feature class from an enterprise geodatabase. It runs and it actually does update the attribute table but this ArcGIS Pro does not acknowledge this.  That means then next task which runs a model to select data based on data created in the previous step does not select anything since Pro doesn't think there is anything to select.
I have all this set up in scrips and tasks as we are automating as much as possible a process for non-GIS staff.  To ask them to remember to go to List by data Source in the the Catalog pane, find the right data source connection (there are lots in the project), right click and choose refresh is a lot. And to remember to do it before the next step in the process is another thing again.  I really need a solution.
I came across this in Stack Exchange - it's a bit old now but is it actually possible to automate a data source refresh from Tasks?  I've been trying all sorts of things but I can't get it to work.  If it is possible, any help/instructions on how to do this would be fantastic.
Michele_Hosking
Ok - found a horribly clunky work around where we calculate a dummy record as part of a task in one layer and it refreshes everything in the map.
Dennis1
I came across that same Stack Exchange post but I cannot figure out a way to make it work through a task. I am able to use the record function to add the command to the task but when that step of the task is run it fails.
Michele_Hosking
Sorry - I would have taken some screen shots to show you but we have ditched all the scripts and are doing everything in attribute rules now. Much harder to get working correctly as it seems super finickity but at least we don't have this issue now. From what I can remember I put in a step to select the dummy records and then I think I did the calculate in the next step..?  And both of these were hidden and run automatically so the user didn't see them.
