Can't see Feature Services from ArcGIS Server in Pro
3487
04-20-2020 01:45 PM
MichaelSnook
Hi All,
I recently published a feature service from to a stand alone ArcGIS Server instance for editing.  When I add the server to pro using credentials that have access to the service I can only see the Map Service in the Pro catalog pane.  I would expect to see both the map service and the feature service as shown in the help docs:
Add a web feature layer for editing—ArcGIS Pro | Documentation
(Step 6 under 'Use an ArcGIS Server connection' section).
I can add the individual feature service layers for editing by URL just fine.
Any help would be great.  (Using Pro 2.5 and Server 10.8)
Mike
JaniceBaird
I have the same problem. I am using ArcGIS Server 10.8 (stand-alone) and Pro 2.8. Is it possible that issue is still an issue after more than a year! I'm really not surprised. Did you ever figure this out?
Janice.
